Old 01-11-2009, 04:58 PM   #1
Furnace won't reset
Have a up north home and during winter months we experience power losses and the gas forced air furnace will not reset when power returns. Has caused frozen pipes, any ideas. thanks
DOUGLAS1 is offline   Reply With Quote
Old 01-11-2009, 05:11 PM   #2
JohnH1's Avatar
Furnace won't reset
Why dosent the furnace reset when the power returns? It should just turn back on without any help.
What type of heating system do you have?
JohnH1 is offline   Reply With Quote
Old 01-11-2009, 05:33 PM   #3
Furnace won't reset
gas fired hot water boiler
Old 01-11-2009, 11:21 PM   #4
JohnH1's Avatar
Furnace won't reset
There is no reason a loss of power should keep the boiler from restarting once the power is restored. The only thing I could posably think of is if your thermostat is battery powered and batterys went dead. What steps do you take to get running again? You may want to concider adding glycol (antifreez) to the system if powerloss is a common problem. This will help protect the heating system.
Old 01-12-2009, 11:11 PM   #5
Furnace won't reset
replace the primary. losing power shouldnt put your boiler into reset anyway.
thelimit is offline   Reply With Quote
Furnace question cuts off until I hit the reset switch bmvrdv HVAC 7 12-09-2008 10:54 AM
Furnace Reset Issue Syzygyone HVAC 2 12-01-2008 09:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
HEIL furnace keeps kicking off reset switch sunsetacres1318 HVAC 8 11-04-2008 09:35 AM
