Old 10-10-2006, 08:58 PM   #1
Do it myself - Girl Power
Question
Furnace won't lite-Coleman Model 900759-Help
Hello to everyone - here is my first question...
I cannot get the furnace to lite. Does anyone have information on this furnace ? It is fed by Propane. Do I have to lite the pilot myself?????
Thank you for any information you may have.
AS
asstratford is offline   Reply With Quote
Old 10-11-2006, 08:19 AM   #2
Does this unit have a standing pilot or electronic ignition?
redline is offline   Reply With Quote
Old 10-12-2006, 11:55 AM   #3
It is so old, I'm sure it's a standing pilot.
Old 10-12-2006, 11:58 AM   #4
can you see if the pilot light is even lit?
Old 10-18-2006, 05:24 PM   #5
Thoroughbred Mopar Man
Hi Asstratford
This particular furnace should be electronic ignition. Locate the gas valve. There should be two white wires and a gray wire going inside the furnace just below the gas valve. If that is so, you probably just need a new hot surface ignitor. The part # is 1474-052p
Good luck, let me know if you need any more help.
Rusty
#CARRIERMAN is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
