Furnace Won't Light - Help! - HVAC - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 04:01 PM   #1
Furnace won't light - help!
Have an older WeatherKing furnace that started acting up a few days ago. Put in a new thermostat, but didn't solve the problem. Also checked for any loose wires and made sure I had a good ground.
When I turn the thermostat on, the pilot light in the furnace comes on, and I hear a continual clicking. It either takes several minutes for the burners to ignite, or they don't fire up at all.
Help!?
friarpuck is offline   Reply With Quote
Old 03-30-2013, 05:24 PM   #2
Rewards Points: 582
Help!?
not sure what model you have ..check size of pilot ..and see if its hitting flame sensor....if it is good and strong and hitting flame sensor...replace flame sensor 1 st...ben sr
Old 03-30-2013, 05:28 PM   #3
An old Tradesmen
Rewards Points: 8,168
Clean flame sensor.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-30-2013)
Old 03-30-2013, 09:27 PM   #4
Cleaned oxidation off of flame sensor and it fired right up -- thanks guys!
The Following User Says Thank You to friarpuck For This Useful Post:
Doc Holliday (03-30-2013)
Old 03-30-2013, 09:37 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
glad you got it. this site is always here when you need us.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Furnace pilot light will not ignite - Carrier 58 GS Furnace? rasilun HVAC 3 10-29-2011 09:38 PM
Furnace will light - if I hit it! Chuch HVAC 1 10-28-2011 02:05 PM
Bryant furnace won't light, not HSI amylynn6 HVAC 8 11-01-2010 10:07 AM
Weathermaker 8000 gas furnace will not light karyn HVAC 1 01-24-2010 11:17 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
