Furnace Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 03-26-2007, 04:13 PM   #1
Furnace won't light
We have a keep-rite (i beleive) furnace and it won't light most of the time. The electic igniter does its thing sparking (or arcing whatever you want to call it) but the pilot won't light. We have to turn the furnace off and on or sometimes even blow in at the ignitor to get it to light. Any one have any ideas on this? I tried to find another thread that spoke about this, but most seemed to be about the other ignitors (the ones that glow or heat up).
Babybird is offline   Reply With Quote
Old 03-26-2007, 09:00 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi Babybird It sounds like to me from your thread you need to have the pilot assembly removed and cleaned. This is something that you can do yourself if you are mechanically inclined and are extremely careful not to damage the pilot tube or the pilot assembly. If you are comfortable with that tear into it and give it a try. If you need some detailed instructions let us know. If you are not comfortable with this venture, please call a "qualified" servicing company. Good luck Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 03-30-2007, 09:48 AM   #3
If you have a can of computer air or a portable air tank from the garage, and a nozzle, you can blow directly into the pilot (with the furnace power off) and 9 out of 10 times, it will do the trick with out any or with minimal disassembly. Good Luck ......
harleyrider is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
bryant furnace will not light somany?'s HVAC 16 11-29-2006 08:28 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
