Furnace Wont Light - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 05:11 PM   #1
furnace wont light
comformaker furnace pilot will not light igniter glows but no flame is lite for repeated cycles green indicator flashes 1 time then followed by 6 flashes this is repeated. i have installed new ignighter
am49233 is offline   Reply With Quote
Old 12-19-2011, 05:12 PM   #2
Comfort maker furnace
Pilot light will not light
Old 12-19-2011, 05:42 PM   #3
Won't have a pilot light if it has a hot surface ignitor. It glows red hot then ignites the gas as it comes out of the burner. No flame means no gas hitting the HSI. Does the gas valve have 24 volts to it when the HSI is red hot? Is the gas turned on? Do you hear or smell gas flowing?
Old 12-19-2011, 06:35 PM   #4
HVAC Tech/ Browns Fan
Time to call a hvac company. Sounds like bad gas valve.
Tator1076 is offline   Reply With Quote
Furnace pilot light will not ignite - Carrier 58 GS Furnace? rasilun HVAC 3 10-29-2011 09:38 PM
Furnace will light - if I hit it! Chuch HVAC 1 10-28-2011 02:05 PM
Bryant furnace won't light, not HSI amylynn6 HVAC 8 11-01-2010 10:07 AM
Weathermaker 8000 gas furnace will not light karyn HVAC 1 01-24-2010 11:17 AM
Carrier Furnace Series 160 Pilot Light issue eastons HVAC 2 03-15-2009 02:26 PM
