Furnace Won't Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 01:42 PM   #1
furnace won't ignite
hello,
I have a Goodman furnace model GMP100-3 when turned on the vent motor comes on for a few seconds then I can here what sounds like the gas coming in then it shuts right back off, the exaust fan continues to run. The ignitor does not get hot and the blower motor does not come on after 3 cycles of this the status light blinks once, any ideas as to what may be happening here?
dum guy is offline   Reply With Quote
Old 10-06-2010, 02:06 PM   #2
Rewards Points: 869
not familiar with that model but, look on panel for 1 flash failure code. could be open in hot surface ignitor, diff pressure switch not closing, or one of the other safety devices in series with the 24vac ckt (those are my guesses in order).
TimPa is offline   Reply With Quote
Old 10-06-2010, 03:27 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 402
HSI hot surface igniter is probably burnt out.
Old 10-06-2010, 04:20 PM   #4
Concur
hvaclover is offline   Reply With Quote
Furnace fails to ignite now and then... diitto HVAC 7 11-23-2016 04:19 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Goodman furnace won't ignite.... help. timrec HVAC 2 01-12-2010 09:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
