Furnace Wont Go On Unless Hit. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 03:09 PM   #16
A buddy of mine had an issue like this. Before replacing parts we pulled all the connectors one by one and cleaned them up with a small wire brush. Worked like a charm
AdRock is offline   Reply With Quote
Old 01-26-2013, 03:29 PM   #17
Furnace wont go on until hit
I posted here months ago but never fixed my issue. My furnace is worse the ever. Now it won't go I until I hit every time. I recorded this video and think I know where the issue exist. Looks like the air pressure switch. Any thoughts? Video link below
http://youtu.be/1zls5zOAcq8
ray0890 is offline   Reply With Quote
Old 01-26-2013, 03:37 PM   #18
Rewards Points: 1,294
It is posible that that switch is not opening when the unit shuts down. A furnace in one of my houses has something on the control board that looks for that switch to be in the open position before it will start the Induced draft blower. It is a safety feature to keep someone from jumpering the pressure switch.
danpik is offline   Reply With Quote
Old 01-26-2013, 03:43 PM   #19
So any ideas on fixing it. Does the switch need replacing?
Old 01-26-2013, 03:55 PM   #20
If it is faulty then yes. I would test it out with an OHM meter first
Old 01-27-2013, 08:50 AM   #21
An old Tradesmen
Rewards Points: 6,124
Merged you 2 threads.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
