Furnace Wont Go On Unless Hit. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 10:02 PM   #1
Furnace wont go on unless hit.
During hurricane Irene last year my basement flooded (about 1 foot if water) and caused danger to my furnace. I realized that all that seemed to be damaged was the circuit board. So I went online ( I am a total novice ) and googles the issue and found I could buy and replace it myself. I did and it seemed to work. The only issue I have is sometimes it won't go on until I literally hit the furnace no to hardly and then it goes on. What could be the issue? I attached a YouTube video of the issue as well.
http://youtu.be/KAPrO4EXlrw
ray0890 is offline   Reply With Quote
Old 11-19-2012, 10:14 PM   #2
how
Rewards Points: 1,104
Something electrical is loose. Thermostat connections inside the furnace/ door switch/ etc.
I would check over the connections on your board since you've just changed it.
Another question I have is do you have enough room in front of the furnace to ever change the blower motor?
how is online now   Reply With Quote
Old 11-19-2012, 10:19 PM   #3
I will reconnect it all tomorrow not sure I I have enough room. I added another picture maybe you can tell.
Old 11-20-2012, 10:14 AM   #4
Furnace wont start up unless hit.
During hurricane Irene last year my basement flooded (about 1 foot if water) and caused danger to my furnace. I realized that all that seemed to be damaged was the circuit board. So I went online ( I am a total novice ) and googles the issue and found I could buy and replace it myself. I did and it seemed to work. The only issue I have is sometimes it won't go on until I http://youtu.be/KAPrO4EXlrwliterally hit the furnace no to hardly and then it goes on. What could be the issue? I attached a YouTube video of the issue as well.
Old 11-20-2012, 10:25 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 412
I say a loose connection.
You are not hitting that thing hard enouogh to move anything inside, but the wires may be close to where you tap it.
jbfan is online now   Reply With Quote
Old 11-20-2012, 10:34 AM   #6
Here's a pic on the inside if it I will check connections tonight
Old 11-20-2012, 12:56 PM   #7
JJboy's Avatar
Turn off the Tstat and jumper R-W on the furnace.
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 11-20-2012, 01:06 PM   #8
Rewards Points: 582
yep you have a loose connection somewhere.....ben sr
Old 11-20-2012, 05:18 PM   #9
Nope. You won't get the blower out with that clearance.
hvac5646 is offline   Reply With Quote
Old 11-20-2012, 05:36 PM   #10
Jjboy... I can turn off the thermostat but what do you means by the r-w??
Old 11-20-2012, 11:45 PM   #11
JJboy's Avatar
The control board you installed. There are the low voltage wires connections coming from the thermostat. If you turn off the thermostat and jumper R-W at the control board, the furnace will turn on. You can check if the loose connection is inside of the furnace or the thermostat wires.
Old 11-21-2012, 10:24 AM   #12
I had a new carrier furnace installed and it did the same thing, had to wake up in the middle of the night and hit the darn thing, the service guy never figured it out because it always worked when he came to the house,turns out is was the switch on the door, I just shorted it out, problem solved.
bungalow_steve is offline   Reply With Quote
Old 11-21-2012, 10:30 AM   #13
Rewards Points: 13,458
Was that salt water that got in?
I would have replace the whole unit. Keep an eye on it, I'm betting the whole bottom area that was under water is going to rust out.
Old 11-21-2012, 10:45 AM   #14
No it was not saltwater. No rust will check door Switch though because that sound logical.
Old 11-21-2012, 10:59 AM   #15
If it is the switch, replace it do not bypass it!
It's there for your safety.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
