Furnace Won't Fire... - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 12:51 PM   #1
My furnace won't fire, and I can't figure out why. The exhaust blower starts, and that's all I get.
It has a new board, new blower motor, and the lines going to and from the exhaust are all clean.
It still has gas supply, but never ignites. It doesn't have a pilot light that burns continually, it has an auto-igniter. Could that be the issue?
Thanks,
Jason.
Need2Know is offline   Reply With Quote
Old 10-04-2010, 01:02 PM   #2
HVAC / Plumbing
check ps . It has to make up b-4 it will fire.. Also could be HSI do you hear gas come out on call for heat ??
kenmac is offline   Reply With Quote
Old 10-04-2010, 01:23 PM   #3
abreviations...
well, I don't really know HVAC terms, I just do what I can, so I don't really know what an HSI is, and I'm assuming ps is pressure system?
I'm wondering if there's a bad solenoid, I'll go down there in a bit and listen for gas.
Old 10-04-2010, 01:27 PM   #4
HVAC / Plumbing
ps = pressure switch. This has to make up b-4 firing. There is a hose that comes off the vent motor & connects to the ps.. HSI = hot surface ignitor. It glows red & ignites the gas as it comes out of the burners or pilot assy.
Old 10-04-2010, 01:37 PM   #5
switch!
Pressure switch! I should have known that!
After all the years I spent in mold temperature control units!
I'll check those first.
Thanks again!
Old 10-04-2010, 03:23 PM   #6
ps okay...
It makes the PS. I never hear gas start to flow however, so I'm guessing its the solenoid.
It has a Honeywell Smartvalve. Also, the model of the furnace is an Armstrong Ultra 93.
Old 10-04-2010, 05:23 PM   #7
HVAC / Plumbing
O' I'm sorry...you have the dumb valve..It can be checked.. I just don't feel comfortable telling you the easy way check them because of FIRE hazard due to your experence level..
You may need to call a pro
Tags
check igniter , cold house , gas furnace problem , please help , won't ignite
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Ruud Furnace Won't Fire jasonckcmo HVAC 26 12-01-2009 07:55 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
