Furnace Won't Come Up To Heat. - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2009, 12:59 AM   #1
Furnace won't come up to heat.
My Lennox Innovator furnace won't come up to heat. It comes on, runs for 10 minutes and then turns off. The thermostat is set at 19.5 and the furnace shuts off at about 17.5. I have read the discussion on flame sensors and on ignitors but don't see those as the problem clearly. In Edmonton it is 40 below and I would love a solution. Thanks.
decondor is offline   Reply With Quote
Old 12-14-2009, 06:03 AM   #2
An old Tradesmen
Rewards Points: 6,464
Check air filter.
Could be a thermostat problem. Have you checked your furnace for error codes.
Your may or may not have that ability.
Old 12-14-2009, 03:11 PM   #3
thank you, beenthere
Thanks very much for your kind help.
I have done a hard reset of the thermostat. I have cleaned the air filter. I know nothing of error codes. i will be looking for a resource to tell me about error codes for my furnace.
How would i know if the thermostat is malfunctioning?
David
Old 12-14-2009, 03:43 PM   #4
An old Tradesmen
Use a meter to see if its sending voltage the the W terminal at the furnace control board.
new carrier heat pump furnace wont cool home wisjr HVAC 8 08-12-2009 01:23 PM
oil heat furnace coil RAMAN62 Plumbing 1 05-09-2009 08:08 AM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 10:09 PM
Carrier 58MCA Furnace No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 08:32 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
