Old 10-07-2012, 01:21 PM   #1
Furnace will not stop running
What could be the problem
BigJim Moved thread from Electrical to HVAC
Hardraymo59 is offline   Reply With Quote
Old 10-07-2012, 03:02 PM   #2
biggles's Avatar
are you melting or is it just the supply fan...if your swetting pull the stat off the subbase lets hear back
Old 10-07-2012, 03:40 PM   #3
how
If your too hot, remove one of the thermostat connections from the furnace.
Dis connecting "R or W" will show you that it's a thermostat or thermostat wire circuit problem if the burners then shut down..
If it's just the fan that won't stop, then a overheating furnace with a tripped limit is a common cause. Dirty filters?
Thermostat fan control on or shorting?
Let us know.
how is offline   Reply With Quote
Culligan N8 Water Softener won't stop running during recharging jacladek Plumbing 41 05-31-2012 12:17 AM
Heil Gas Furnace Keeps Running doombilly HVAC 2 11-13-2011 10:27 AM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Hot water won't stop running rickp47 Plumbing 8 02-19-2009 05:33 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
