-   -   Furnace will not stop running (http://www.diychatroom.com/f17/furnace-will-not-stop-running-159293/)
Hardraymo59 10-07-2012 01:21 PM
What could be the problem
BigJim Moved thread from Electrical to HVAC
biggles 10-07-2012 03:02 PM
are you melting or is it just the supply fan.:huh:..if your swetting pull the stat off the subbase lets hear back
how 10-07-2012 03:40 PM
If your too hot, remove one of the thermostat connections from the furnace.
Dis connecting "R or W" will show you that it's a thermostat or thermostat wire circuit problem if the burners then shut down..
If it's just the fan that won't stop, then a overheating furnace with a tripped limit is a common cause. Dirty filters?
Thermostat fan control on or shorting?
Let us know.
