Furnace Will Not Fire - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2013, 11:10 AM   #1
furnace will not fire
I have a RHEEM RGDG- 100 AUER gas furnace that will not fire, the pilot was out and I started that but nothing else happens just a humming noise...Its getting cold help
flash013 is offline   Reply With Quote
Old 10-27-2013, 11:25 AM   #2
Rewards Points: 77
Is your themostat calling for heat (is your furnace getting the signal)?
mlijoi is offline   Reply With Quote
Old 10-27-2013, 11:34 AM   #3
I changed the batteries in the themostat and it says heat on, also the furnace is making a humming noise
Old 10-27-2013, 11:48 AM   #4
FClef's Avatar
Rewards Points: 160
Can you determine where the humming is coming from? Is it a motor, a transformer, the gas valve, or a control?
Pictures may help.
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
Old 10-27-2013, 12:05 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
post 2 pics of it with both doors off so we can see which exact model U have.
Old 10-27-2013, 01:10 PM   #6
pictures
furnace will not fire-moto_0583.jpg   furnace will not fire-moto_0584.jpg   furnace will not fire-moto_0585.jpg
Old 10-27-2013, 02:19 PM   #7
Hvac Pro
yuri's Avatar
Press the door switch in and put duct tape on it to keep it closed. Check for 24 volts between W and C on the circuit board. The humming is the transformer and OK. If no 24 volts check between R and C. If no volts then a fuse is blown. First thing that should happen is the exhaust fan starts. If no volts between W and C then the thermostat may be bad ( if you have 24 volts between R and C).
Old 10-27-2013, 02:32 PM   #8
Rewards Points: 582
that is a criterian furnace with a standing pilot.... clean pilot and replace thermocupler and make sure its fully engulfed in the pilot....ben sr
Old 10-27-2013, 03:40 PM   #9
I read 27 volts
Old 10-27-2013, 03:48 PM   #10
Hvac Pro
yuri's Avatar
where? If you have 27 volts between W and C then the exhaust fan should run. If not it is seized up or the circuit board is bad.
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 01:14 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Changed gas ball valve and York furnace won't fire, please help. philsoldat HVAC 35 11-03-2010 11:12 AM
my furnace wont fire... please help! chrider88 HVAC 7 01-22-2010 09:43 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
