-   -   furnace will not fire (http://www.diychatroom.com/f17/furnace-will-not-fire-189320/)
flash013 10-27-2013 12:10 PM
I have a RHEEM RGDG- 100 AUER gas furnace that will not fire, the pilot was out and I started that but nothing else happens just a humming noise...Its getting cold help
mlijoi 10-27-2013 12:25 PM
Is your themostat calling for heat (is your furnace getting the signal)?
flash013 10-27-2013 12:34 PM
I changed the batteries in the themostat and it says heat on, also the furnace is making a humming noise
FClef 10-27-2013 12:48 PM
Can you determine where the humming is coming from? Is it a motor, a transformer, the gas valve, or a control?
Pictures may help.
yuri 10-27-2013 01:05 PM
post 2 pics of it with both doors off so we can see which exact model U have.
flash013 10-27-2013 02:10 PM
3 Attachment(s)
pictures
yuri 10-27-2013 03:19 PM
Press the door switch in and put duct tape on it to keep it closed. Check for 24 volts between W and C on the circuit board. The humming is the transformer and OK. If no 24 volts check between R and C. If no volts then a fuse is blown. First thing that should happen is the exhaust fan starts. If no volts between W and C then the thermostat may be bad ( if you have 24 volts between R and C).
ben's plumbing 10-27-2013 03:32 PM
that is a criterian furnace with a standing pilot.... clean pilot and replace thermocupler and make sure its fully engulfed in the pilot....ben sr
flash013 10-27-2013 04:40 PM
I read 27 volts
yuri 10-27-2013 04:48 PM
where? If you have 27 volts between W and C then the exhaust fan should run. If not it is seized up or the circuit board is bad.
