Furnace Water Leak - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 01:47 PM   #1
Furnace water leak
We have York furnace a few yrs. old. we have water leak issue inside the furnace which causing corrosion and the furnace does not work anymore. There are sign of leak and corrosion on vent pipes.
Prior to this we never had issue with furnace (I believe different brand)
Service guy can't figure out where the water is coming from.
what is the problem?
Lilie is offline   Reply With Quote
Old 03-05-2012, 02:37 PM   #2
is this an 80 or 90 plus furnace.
hvac5646 is offline   Reply With Quote
Old 03-05-2012, 02:45 PM   #3
Is there a tee where the venting exits the furnace?
If there is. Is there a trapped drain comming off mbottom of tee? Check all joints for leaks and maybe re-connect with proper glue.(high eff. Only) also check all connections of drain and pressure hoses for leaks! Make, model and type are important! If a mid-eff. Other issues may apply. To large diameter of venting, liner may be req'd also check cap on top of chimney. Hope this was helpful.
JSCOTTYB is offline   Reply With Quote
Old 03-05-2012, 02:48 PM   #4
Furnace water leak
is this what you need to know? what do you mean by 80 or 90 plus?
the unit model: LY8S060A12DH11A
Unit input: 57 BTU/Hr. - 16.7 kW/h
Unit output: 45.6 BTU/Hr. - 13.4 kW/h
Old 03-05-2012, 02:53 PM   #5
An old Tradesmen
Rewards Points: 7,396
Post pic of areas whee water is at.
Sounds like you may have an over size chimney. or your temp rise over the heat exchanger is too low.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-05-2012)
Old 03-05-2012, 02:55 PM   #6
yes there is T for the vent. one side connected to water heater the other side to furnace.
some people told me its not a good idea to have T vent. but I check a couple of other furnaces with T vent without problem.
Old 03-05-2012, 02:59 PM   #7
An old Tradesmen
Is this a some what new furnace. And if so, was the old furnace a standing pilot furnace.
Old 03-05-2012, 04:10 PM   #8
Chicago, IL
Michael Thomas's Avatar
Usually, when I see this and there is no other obvious source, it's a crack in the inducer housing or its connection to the vent pipe above.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 03-05-2012, 04:39 PM   #9
Rewards Points: 582
picture of unit with door off
Old 03-05-2012, 04:49 PM   #10
AKA HVACTECHFW
Rewards Points: 1,208
BT is right. It is an 80% eff. Most likely an oversized flue. WE NEED PICTURES!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-05-2012, 08:44 PM   #11
Furnace water leak
http://www.colemanac.com/PDFFiles/03...001-B-1205.pdf
Here is the online photo, our furnace the 3 burner, of the furnace the water accumulates under the burner.
Old 03-06-2012, 07:29 AM   #12
Where are the pics
Old 03-06-2012, 04:17 PM   #13
An old Tradesmen
Its just a link to the manual, not a real pic of the furnace.
Old 03-07-2012, 01:36 AM   #14
Furnace water leak
Furnace front under the cover
Old 03-07-2012, 06:31 AM   #15
Rewards Points: 582
wow you have more than just a water problem tell me there not and a/c coil on top of downdraft furnace..
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 12:40 AM
