Furnace Venting Question - HVAC - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 12:05 AM   #1
Hi:
I have a 95% Rheem furnace which has a 3" PVC exhaust vent running horizontally across the basement to the outside. The combustion air is from the basement. I have a natural draft gas water heater which is vented into my 12", single flue chimney with no stainless steel liner. My question is: Is there a code-compliant way to vent both the furnace and the water heater up the chimney?
Vulcanus is offline   Reply With Quote
Old 09-11-2011, 03:11 AM   #2
30 year tech
hvac122's Avatar
No they must be vented separately.
hvac122 is offline   Reply With Quote
The Following User Says Thank You to hvac122 For This Useful Post:
Vulcanus (09-11-2011)
Old 09-11-2011, 06:19 AM   #3
An old Tradesmen
Rewards Points: 8,234
And your water heater isn't allowed to be vented into a 12" chimney. The chimney needs to be lined for the water heater.
The Following User Says Thank You to beenthere For This Useful Post:
Old 09-11-2011, 11:47 AM   #4
OK, thanks. I'll scrap that idea.
Old 09-14-2011, 10:47 PM   #5
Can I vent the furnace and water heater through the same chimney flue if I install two 3" stainless steel liners, one for the furnace vent and the other for the water heater?
Old 09-14-2011, 10:50 PM   #6
An old Tradesmen
Your furnace is not approved for stainless steel vent pipe. Or At least I've never seen a 90% plus efficient hot air furnace that was approve for it. Many boilers are though.
Old 09-14-2011, 10:56 PM   #7
OK, thanks again.
I've seen water heaters which have a PVC vent. If I replace the water heater with that type, would it then be permissible to vent the furnace PVC and water heater PVC in the same flue?
Old 09-14-2011, 11:00 PM   #8
An old Tradesmen
They could both have their PVC pipes ran up through the same chimney.
Old 09-14-2011, 11:04 PM   #9
OK, Thanks a third time!
I will look into that approach.
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Furnace intake noise question joeg679 HVAC 6 12-11-2009 12:03 PM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 05:14 PM
Options for venting 90+ furnace RM575 HVAC 2 06-17-2007 10:32 PM
