-   -   Furnace Venting Question (http://www.diychatroom.com/f17/furnace-venting-question-116884/)
Vulcanus 09-11-2011 12:05 AM
Hi:
I have a 95% Rheem furnace which has a 3" PVC exhaust vent running horizontally across the basement to the outside. The combustion air is from the basement. I have a natural draft gas water heater which is vented into my 12", single flue chimney with no stainless steel liner. My question is: Is there a code-compliant way to vent both the furnace and the water heater up the chimney?
hvac122 09-11-2011 03:11 AM
No they must be vented separately.
beenthere 09-11-2011 06:19 AM
And your water heater isn't allowed to be vented into a 12" chimney. The chimney needs to be lined for the water heater.
Vulcanus 09-11-2011 11:47 AM
OK, thanks. I'll scrap that idea.
Vulcanus 09-14-2011 10:47 PM
Can I vent the furnace and water heater through the same chimney flue if I install two 3" stainless steel liners, one for the furnace vent and the other for the water heater?
beenthere 09-14-2011 10:50 PM
Your furnace is not approved for stainless steel vent pipe. Or At least I've never seen a 90% plus efficient hot air furnace that was approve for it. Many boilers are though.
Vulcanus 09-14-2011 10:56 PM
OK, thanks again.
I've seen water heaters which have a PVC vent. If I replace the water heater with that type, would it then be permissible to vent the furnace PVC and water heater PVC in the same flue?
beenthere 09-14-2011 11:00 PM
They could both have their PVC pipes ran up through the same chimney.
Vulcanus 09-14-2011 11:04 PM
OK, Thanks a third time!
I will look into that approach.
