Furnace Vent Location - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 09:49 PM   #1
I recently bought a new 95% efficient furnace. I am looking to find out what the laws in my area stipulate in terms of vent locations. The manual that came with the furnace has some guide lines but the they are not clear. Can someone tell me where I can find this info? Or maybe someone knows? I live in a NYC suburb. Thanks.
stevem447 is offline   Reply With Quote
Old 06-29-2013, 12:59 AM   #2
Experienced HVAC Tech
HVAC1000's Avatar
Usually ( this is true in my area, idk about yours) the code actually says to follow manufacturers instructions on all class 2&3 appliance venting. Which includes high efficiency stuff. All requirements should be stated in manufactures booklet. However I agree in that they are often worded in tough to understand ways. You could post sections you don't understand and maybe we can help "translate" them
HVAC1000 is offline   Reply With Quote
Old 06-29-2013, 05:41 AM   #3
Below is the URL to the manual, pg. 14 has the chart and layout of a typical home. My furnace is 70k and according to what I see on the chart it needs to be 12" from a door or Window. I n my case I have a permanently closed basement window, so I should be ok correct?
http://www.alpinehomeair.com/related...%2010-2012.pdf
Some additional questions: What is the difference between "Direct Vent" and "Other than Direct Vent"? I am using a standard exterior vent I assume this is direct? http://www.ebay.com/itm/Goodman-Flus...item3a6322e875
Can I run PVC vent pipe behind my furnace? There is a 14" space between the wall and the furnace.
I have a brick exterior on my home, what is the recommended method for creating the penetrations? I plan on using a hammer drill.
Old 06-29-2013, 05:55 AM   #4
An old Tradesmen
Rewards Points: 7,370
The PVC can run behind your furnace. There is no clearance to combustibles for PVC venting.
It also needs to be 12" above normal snow accumulation level.
Old 06-29-2013, 06:28 AM   #5
Roger that, I am putting it under an over hang with a gutter attached, that should help to prevent snow buildup.
Old 06-29-2013, 06:30 AM   #6
raylo32's Avatar
Rewards Points: 1,284
I did this myself at my house a couple years ago using the same type of vent. Make sure you look closely at all the clearances in the manual. I believe they all come from the National Fuel Gas Code. On my house there was only one single sidewall location that satisfied all of them. Otherwise I would have had to go up to the roof, which would have been almost impossible and prohibitively $$.
I also had brick in the location of my vent. Instead of drilling them out I broke out the mortar and removed whole and half bricks to make a rectangular opening. Then I inserted a piece of pressure treated 2x6 by lumber cut to fit and glued it in with construction adhesive. Then I drilled that out for the pvc.
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
MTN REMODEL LLC (06-29-2013)
Old 06-29-2013, 07:18 AM   #7
I read the instructions in the manual, it looks like the diagram says that the specs given are National Standards. I was concerned that there might be local standards as well. According to the manual I need to be 12" above the snow line (where do you determine the official snow line?), and 12" from any Window or door. I have a permanently closed window in the basement I was planning on using the area adjacent to that.
Great Idea with the brick, I do not have good masonry skills however.
Old 06-29-2013, 07:34 AM   #8
raylo32's Avatar
I'd be really conservative with the snow line especially if it is a place on your house that tends to accumulate drifts.
I am remembering more of my job now... my brick was backed by concrete block so I did use a hammer drill and cold chisel to make the rectangular opening in that. The pressure treated piece is glued into the concrete block.
Old 06-29-2013, 07:37 AM   #9
Rewards Points: 242
When drilling through brick, rent a rotary hammer drill with the size bit you need from home depot. a 2" PVC will use a 2 1/2 " carbine bit. you have to drill from the outside because it will blow out the back of the brick. it makes a real nice opening and then all you do is use a little caulk around it. one of these drills cost about a thousand bucks with each large drill about 100. it will slice thru like butter. I had a house that had the red foundation brick on the inside and regular brick on the outside. it was 12" thick. it cut thru that in about 90 seconds with a perfect round hole.
hvac instructor is offline   Reply With Quote
Old 06-29-2013, 08:05 AM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
there is no official snow line/level. you can always keep shovelling it away. the 12" is so the pipe does not get blocked with snow and shut off with a safety control/pressure switch. you can always add pipe 2 it later/gooseneck it higher if necessary but it is better to try do it properly the first time instead of in the dead of winter when you have a problem. we don't know your area and everyone's yard is different with wind swirling the snow and building drifts in corners etc.
Old 06-29-2013, 09:06 PM   #11
HVAC1000's Avatar
Direct vent is when you have two PVC pipes connected to the unit. One pulling in air from outside the other expelling flue gas. Non-direct vent is when you only have the one pipe expelling flue and you are pulling in combustion air from inside the structure
Old 06-30-2013, 08:44 AM   #12
The problem with non-direct is that it generates negative pressure in the house, creating a cold draft wherever the air comes in to make up for what went out the flue. 2" PVC is cheap, always run a combustion air vent. If you don't want two wall penetrations, use a concentric vent.
taxmantoo is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Furnace room Vent with fan grod777 HVAC 2 10-31-2011 09:14 AM
Smoke and Vent on a New Lennox Furnace Handymannabee HVAC 3 04-13-2011 03:46 PM
Direct Vent Wall Furnace - Pilot-Help !! roztom HVAC 4 04-28-2010 10:25 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
