Furnace Vent Cover? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 02:54 PM   #1
Rewards Points: 324
Furnace Vent Cover?
Hello,
I am curious for you HVAC experts whether a wire mesh cover is necessary for furnace vent on the roof? My HVAC guys says no way since it could lead to ice build up etc and looks like placed a 45. I tend to think you need something to prevent birds from nesting? Please disregard red circles - I recognize some of these are NOT hvac but just bath vents and radon vent.
Your thoughts?
Here is the cover I was thinking:
sbkim is offline   Reply With Quote
Old 10-18-2012, 03:40 PM   #2
Rewards Points: 610
I earlier said on different thread...no problem but, did not realize you were talking about furnace vent so must retract...I have seen mega ice build up on units wthout screens so, definitely do not add screen
techpappy is offline   Reply With Quote
Old 10-18-2012, 03:45 PM   #3
An old Tradesmen
Rewards Points: 6,500
Thats one of the good ice makers. Known to have caused many many no heat problems.
In areas where it is code to put one in. After it passes inspection, I remove it.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (10-18-2012)
Old 10-18-2012, 04:27 PM   #4
Rewards Points: 324
Wow - great info. Thank you so much guys. For sure, I am not going to put guards on HVAC vents but what about:
1. Passive radon pipe
2. Bathroom fan
Am I asking for trouble by putting grill/guards on these - see pictured above?
Many thanks and sorry for stupid questions...
Old 10-18-2012, 05:39 PM   #5
Leave them open. Birds rarely try to nest in straight vertical pipes. They'll probably like the neck on that 45 though.
The Following User Says Thank You to Marty S. For This Useful Post:
sbkim (10-18-2012)
Old 10-18-2012, 06:43 PM   #6
Rewards Points: 582
if you were in my area alot of contractors would say put it in....why because it creates service calls it will ice up and shut down your furnace.....want to know how much a call for going up on the roof in the dead of winter....well lets just say.. leave the screen out....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
sbkim (10-18-2012)
removing wall vent cover help numpty HVAC 4 05-03-2012 08:00 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
gas fireplace with same vent as furnace & water heater? Van3 HVAC 0 01-30-2011 05:21 PM
New furnace, new placement, vent pipe horizontal run length allowed? WillK HVAC 1 01-23-2011 08:16 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
