Old 01-13-2008, 06:46 PM   #1
Question
Furnace Vent
Hello. Just had a Carrier Infinity Furnace put in [scrach and dent]. the 2'' vent going to the outside sounds like gurgling water when running. The pvc is most level and doesn't have enough of a drop. Will this in anyway harm the furnace? thanks..
abfhand is offline   Reply With Quote
Old 01-13-2008, 09:57 PM   #2
Furnace Vent
yeah if you here water gurgling that is not a good thing, if it is almost level, then that is not good enough you need rough 1/4" per 3 feet slope is the general rule of thumb so you might want to take a look at having that fixed
mgv79 is offline   Reply With Quote
Old 01-13-2008, 10:15 PM   #3
30 year tech
hvac122's Avatar
Furnace Vent
As said you need slope so the condensation drains back to the furnace and out the condensate. Not sure about Carrier but most manufactures say 1/4" per foot. If this is not done then you may get intermitent failures.
hvac122 is offline   Reply With Quote
Old 01-13-2008, 11:55 PM   #4
Union HVAC Tech.
Furnace Vent
1/4" per foot as the man said.
bigMikeB is offline   Reply With Quote
Old 01-14-2008, 03:43 AM   #5
Furnace Vent
Thanks for the inputs. We couldn't place a concentric kit out there because of the way the joists are running. Had to do a back 'S' using 45's to go above the poured basement wall. It is probably a 30' run from the furnace to the outside. Strange thing is, from the outside back - the pipe is probably an inch and a half lower on the furnace side and 4' from furnace is showing mostly level. Really don't know how fix that now.. Thanks again. Will
Old 01-14-2008, 04:49 PM   #6
Union HVAC Tech.
Furnace Vent
Couplings.
Old 01-14-2008, 05:00 PM   #7
Furnace Vent
How many bends are in the run?
redline is offline   Reply With Quote
Old 01-14-2008, 05:12 PM   #8
Furnace Vent
3 not counting the outside 90 & 45.
The only way I'm gonna get it right is to cut the pipe where it goes into the furnace side joist and make that hole deeper so the pipe will be lower and shorten the pipes to the furnace. It mostly gurgles for a few seconds on the pipe outside then smooths out. Plenty of steam from the exhaust showing it's getting thru okay but still hear the girgling.
It's a Carrier gas furnace Infinity 80,000 96
vent bathroom fan to furnace vent jcrampton HVAC 16 10-12-2012 12:24 AM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Is my furnace a direct vent or power vent? wease HVAC 5 02-02-2007 08:55 AM
