Furnace Turns Off After 3 Min - HVAC - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 11:49 AM   #1
furnace turns off after 3 min
carrier unit. error code 33. burners come on for 3-4 min then cuts off.
sanded iginiter, checked limit switch, checked relay, duct work not blocked, filte clean, blower motor seems to be working properly. Any ideas? circuit board maybe? Any help would be appreciated.
kg321 is offline   Reply With Quote
Old 01-07-2008, 05:02 PM   #2
HvacWiz's Avatar
Rewards Points: 252
Possibly plugged condensate drain or trap.
HvacWiz is offline   Reply With Quote
Old 01-08-2008, 03:31 PM   #3
update
The problem was the A-coil was filthy, not enabling heat to escape, causing limit switch to kill heat, as it was sensing too hot. air mvmt/ blockage was an option but I just didn't even think about the a-coil.
thx....kg
Old 01-09-2008, 05:37 PM   #4
Union HVAC Tech.
Better buy an igniter. Never touch the igniter and never sand it.
bigMikeB is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Malfunctioning Tappan Furnace atlfiveo HVAC 3 01-27-2010 12:27 AM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
