Old 11-07-2011, 07:48 PM   #16
HVAC Tech/Owner
Furnace Troubles
Originally Posted by Pancho529 View Post
This furnace is 11 years old. Therefore, I don't think the ductwork is too small. The motors are running fine, that's not an issue either.
the age has nothing to do with too small of ductwork....I am working with a customer now with a 10 year old furnace that cycles on the limit....been doing it since it was new and the homeowner never noticed.
Technow is offline   Reply With Quote
Old 11-07-2011, 08:41 PM   #17
Furnace Troubles
Thanks for the replies. I cleaned the flame sensor. The filter is less than a month old and looks clean. I don't think the ductwork is an issue and I don't see anything blocked or particularly messy. The problem I'm having right now is that my igniter is not even glowing (which is what has been giving me trouble the whole time before I noticed the burner putting itself out within a couple minutes). Before, I was able to get it to come on and ignite the burners. The problem then was that the burner went out within a minute or two.
Pancho529 is offline   Reply With Quote
Old 11-07-2011, 10:08 PM   #18
An old Tradesmen
Furnace Troubles
Is the blower running when the burner goes out.
Old 11-07-2011, 10:22 PM   #19
I'm Your Huckleberry
Furnace Troubles
On the aforementioned Lennox furnace that I thought was a bad ignitor as it woudn't light with full voltage to it, old ignitor and brand new one, it ended up being the pressure switch tube port of the draft inducer motor partially clogged. Weird thing was the pressure switch would close and open with inducer on and off as normal but it wouldn't allow the furnace to light up until I cleared the port.
Hope that helps.
Doc Holliday is online now   Reply With Quote
Old 11-08-2011, 05:25 AM   #20
Furnace Troubles
Yes it is.
Old 11-08-2011, 07:16 PM   #21
An old Tradesmen
Furnace Troubles
Check the discharge air temp.
Old 11-09-2011, 10:51 PM   #22
Furnace Troubles
Got the furnace fixed. Apparently the issue was my high limit switch. I thought I had replaced it, but it was the roll out switch that I replaced. I told the parts store that I needed the high limit switch and brought in the roll out switch being misinformed and yet they still gave me the wrong part.....
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 08:21 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
