Furnace Trouble After Running Dry - HVAC - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 11:59 AM   #1
Hi, my oil burning furnace (for both baseboard and supply) had run out of fuel 2 days ago, we got a delivery yesterday, so I went to fire it up again. I was told I would only have to bleed the fuel line if the boiler didn't fire, but it went first shot. I'm not a pro on boilers by any means, but I believe I've lost pressure on the expansion tank side (also the line that runs to baseboard heating).
This is on a Thermo Dynamics model S-125, ~10yrs old.
As soon as it fired back up, the hose nozzle on the same pipe as my T/P RV (about 1" apart on the pipe, 90 degrees difference, valve is at the end of the straight pipe) started releasing all the water going through that side. I can stop the hot water dump by turning off the baseboard/expansion tank side, but that doesn't get me a fully functional boiler. Currently we have full running hot water, and though the heat isn't necessary in the summer, I'd rather not wait to get this working properly again.
A few questions here:
- Is that nozzle in the rear the release for the valve, or would it come out through the outlet blocked by the valve?
- Do I need to drain/repressurize my expansion tank, and if so... how?
Any advice is more than welcome, and I can provide pictures or more information for clarity.
Thanks in advance.
basscop5000 is offline   Reply With Quote
Old 06-30-2010, 05:11 PM   #2
An old Tradesmen
Rewards Points: 6,072
Post pics of the devices you are talking about.
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 09:04 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
gas furnace keeps running thermostat off cblake HVAC 1 03-31-2009 01:55 PM
Trouble with my furnace Dan123a HVAC 1 01-23-2009 08:55 AM
