Furnace Thermostat Relocation - HVAC - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 02:54 PM   #1
Rewards Points: 260
Hi all. I need to relocate my thermostat from one wall to another in order to make room for my new wall mounted TV . Can anyone tell me if there is anything else involved other than disconnecting the wire, rerouting it, and then reconnecting it? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 09-03-2013, 03:39 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Jesse
Make sure new location does not get direct sunlight, position stat at the same height it is currently.
Odds are the existing wire will not reach the new location, may need to run new wire.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
jpearson311 (09-03-2013)
Old 09-03-2013, 04:32 PM   #3
Rewards Points: 446
Make sure you turn the power off first! Take notes and pictures if this is something new to you.
old_squid is offline   Reply With Quote
The Following User Says Thank You to old_squid For This Useful Post:
Old 09-03-2013, 05:22 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
probably need new wire as most of the time it is stapled to the 2x4s inside the wall. keep it away from hot and cold registers and drafts also.
oil furnace & programmable thermostat Ted Hanley HVAC 2 01-01-2012 12:40 PM
thermostat to furnace wiring Craig66 Electrical 2 11-03-2011 02:57 PM
manual bypass for furnace thermostat. foxsam HVAC 8 11-07-2008 01:20 PM
New Thermostat and Furnace Not Working Right Vegas Resident HVAC 1 12-06-2007 07:42 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
