Furnace/Thermostat Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 12:45 PM   #1
Furnace/Thermostat not working
This morning I woke up to a 60degree house when usually it is set at 67. The furnace is a automatic start so there is no pilot. I have checked the fuse, and for power, everything there seems fine. I can turn on the fan in the fan only mode, and the red light comes on on the thermostat. If I turn the heat above the room temp I can hear the thermostat click, but nothing happens and the red light doesnt come on on the thermostat.
Would this be the thermostat or should I try something else?
Michblaze02 is offline   Reply With Quote
Old 02-23-2010, 01:24 PM   #2
Licensed Master Plumber
It is rarely a thermostat problem. Is this thing oil or gas fired.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-23-2010, 01:43 PM   #3
Gas
It has an ignitor similar to a backyard grill.
Old 02-23-2010, 03:01 PM   #4
Just figured it out. It was the damper, it must of been stuck closed or something. I took the cover off and tapped around on it, and started to hear the clicking noise, it was the damper slowly opening. As soon as that was open it fired up .
So far so good now
Recess lighting spot not working bellezza Electrical 4 11-11-2009 07:04 PM
No heat but working AC xevier69 HVAC 4 01-30-2009 05:31 PM
Light & switch not working jgayle Electrical 1 01-18-2009 05:28 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
