Furnace Stops Working - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 02:16 PM   #1
Furnace stops working
My gas furnace will heat for about 5min then turn off. When i turn the switch at the furnace off then on it will heat again for about 5min.. My therm is set to 72 and in auto/heat. I heard that I may be having a backdraft issue. If so how would one fix it?
motorcity11 is offline   Reply With Quote
Old 10-28-2008, 03:09 PM   #2
What kind of furnace and what efficiency?
dac122 is offline   Reply With Quote
Old 10-28-2008, 05:39 PM   #3
Carrier 80
Carrier eff.80
Old 10-29-2008, 08:28 AM   #4
Check if there is any blockage in your chimney, then the high temperature limit switch and then the temperature sensor. I would also clean your temperature sensor. Let us know what you find.
It's cold already...furnace not working :( bryangwilson HVAC 5 09-11-2008 05:44 AM
Trane xv80 furnace blower not working jim2138 HVAC 2 03-22-2008 05:55 PM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 07:51 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
