Furnace Stops Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 10:54 AM   #1
furnace stops heating
my furnace heats until desired temperature, but stops working/ heating after tha one timet. The fan runs all the time. If i turn the furnace switch off and back on the furnace will heat again.
ashmay is offline   Reply With Quote
Old 01-16-2011, 12:05 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
have you replaced your filter? check for a window in the blower door to look for a led light that flashes a code. Post code and model of your furnace. Code will be present while it has stopped heating your house. WHen you shut the power off and back on you are resetting the control board. Its doing what is doing to protect itself.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Ruud Electric Heating Furnace jacksadvantage HVAC 3 01-15-2010 05:56 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 08:11 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
