Furnace Stays On Regardless Of Thermostat Setting. Where To Find Replacement Parts? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2013, 09:18 PM   #1
Furnace stays on regardless of thermostat setting. Where to find replacement parts?
First of all, it's a mobile home furnace, VEXAR BY YORK. Model # EB15B Serial #WON5514505. Don't want to install wrong part, and haven't had luck finding it locally. Problem its having : after furnace kicks on, heat and blower stays on until you turn off the breaker regardless of thermostat setting. after flipping breaker sometimes it will turn off once or twice, then get stuck on again. I believe this is a sequencer, please let me know if this is correct and where I can find a replacement. Thanks in advance!
Nick
KY123 is offline   Reply With Quote
Old 04-04-2013, 11:14 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
stuck contactor. it happens.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 04-05-2013, 12:28 AM   #3
stuck contactor and/or heat sequencer. try Grainger but I'm not sure if they carry parts for mobile home units or not. have your make, model and serial number of your unit on hand.
Thanks.
Tags
mobile home , sequencer , york
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Is it my furnace or my thermostat? Blows cold and can't shut it off TrilliumLady HVAC 6 12-16-2010 07:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Ritetemp 6036 replacement thermostat deanrfire HVAC 0 01-15-2010 02:12 AM
can't find old replacement parts, need Air Handler coils, junkyard? sammibah HVAC 2 07-02-2006 08:43 AM
