Furnace Specs For 2 Older Units - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 09:42 PM   #1
SFX Group's Avatar
Send a message via MSN to SFX Group Send a message via Skype™ to SFX Group
Smile
Furnace specs for 2 older units
Hi
I am after the confirmed CFM for 2 furnaces if possible.
Luxaire GM9S060B12UP11K (60k BTU @ 92% = 55200BTU)
Payne PG8UAA04209 (88000BTU @ 80% = 70400BTU)
Not sure on the airflow rate though...?
Many Thanks
Ashley
Copyright 2011 - www.ashleygriffin.ca
SFX Group is offline   Reply With Quote
Old 12-05-2010, 05:45 AM   #2
An old Tradesmen
Rewards Points: 8,234
Confirmed CFM would require it to be measured.
The rated CFM is 1200 for the GM9, and 1400 for the PG8. How much you actually get from either, won't be known until its installed and checked.
Old 12-05-2010, 08:42 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 396
No mid efficiency units allowed to be installed in Canada now. Doubt VERY much that the gas inspectors will allow any used units to be installed either. May have damaged heat exchangers.
Old 12-05-2010, 10:17 AM   #4
SFX Group's Avatar
Many Thanks
Ashley
Old 12-05-2010, 10:21 PM   #5
SFX Group's Avatar
Thanks, not up for installing 2nd hand units... unless theres a specific reason for needing a type of unit.
This was to compare the outputs of 2 units.
Many Thanks
Ashley
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
help with specs and spin info on older washing machine wombosi Plumbing 5 04-27-2009 05:57 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
