Old 09-17-2012, 06:52 PM   #1
Furnace sizing question
My 18 year old furnace is a Trane XE60 Model TUP100B948A0, and seems to be a 100,000 BTU/hr furnace.
I am looking at replacing it with a Carrier Infinity 59TN6A which is supposed to be 96% efficiency.
My question is - should I get a Carrier rated at 100,000 BTU or should I get something smaller?
rvmeush is offline   Reply With Quote
Old 09-17-2012, 07:37 PM   #2
Professional
have a load calculation done on your home! You will most likely need smaller. A CORRECTLY sized furnace will not only cost you less in fuel bills, but it will make your home more comfortable.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-17-2012, 08:12 PM   #3
Missouri Bound's Avatar
Do you happen to know the efficiency of your current furnace? Obviously a furnace with 100,000btuh rating and a 80% efficiency is equivalent to a 80,000bthu furnace at 100% (if there was such a thing)
Did your old furnace keep you comfortable? Only you can deciide that. A load calculation is a tool to help with the sizing of new furnaces. It's the best tool available for new construction where there hasn't been a furnace in place as a reference, for both the homeowner and the HVAC company. The best thing you could do is get at least three contractors to evaluate what you have and what you need. Let them each make the calculations rather than you tell them what you need; they are the experts. Unless you plan on installing it yourself more quotes will be a better indication as to where you want to be on both sizing and price.
Do you want it your way or the right way?
Old 09-17-2012, 08:42 PM   #4
I like your approch,Missouri!
bobelectric is online now   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Missouri Bound (09-17-2012)
Wiring question for Trane furnace rvmeush HVAC 1 02-27-2012 10:04 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Furnace intake noise question joeg679 HVAC 6 12-11-2009 01:03 PM
Make up ventilation through return on furnace question creamaster HVAC 8 09-27-2009 05:53 PM
