Furnace Size - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2006, 12:19 PM   #1
Question
Furnace size
I need a small gas furnace 16Wx29Lx39H for a 24x30 cabin,any recommendations?
averyds is offline   Reply With Quote
Old 12-18-2006, 04:58 PM   #2
Are you looking for forced air? Radiant, free standing? the choises are endless.
acefurnacefixer is offline   Reply With Quote
Old 12-18-2006, 05:22 PM   #3
Furnace
Forced air
Old 12-18-2006, 05:38 PM   #4
www.lennox.com
Number 1 in customer satisfaction.
Old 12-18-2006, 06:38 PM   #5
HvacWiz's Avatar
Rewards Points: 252
www.carrier.com
HvacWiz is offline   Reply With Quote
Old 12-18-2006, 11:15 PM   #6
OK, I won't sell you a brand, but I can tell you what you need and where to get it. While I'm sure the gentlemen above me will argue "you get what you pay for", which is why they are pushing a brand, , most heaters have federal standards and guidelines, so I will make sure you get a good heater at a reasonable cost. I do need a little more info though. What is the ceiling height? How old is the cabin? Do you have single or duel pane windows? Do you have an attic to run duct work, or are you looking for a ductless system? The size you gave (24 x 30), is that the full footprint of the cabin, or are there bathrooms and other side rooms? Where is this cabin located so I can look up what temps we are dealing with? With this info, I can give you a system that will take care of your heating needs.
What is your zip code so I can direct you to your nearest HVAC supplier?
sloooo is offline   Reply With Quote
Old 11-22-2008, 11:15 AM   #7
Hvac
It's a duplex, I live on the first floor, each unit has its own furnace, although the second floor has an finished attic. I have 8 windows, 2 exit doors.....the current furnace size it 105000 btu, Sears brand from 1951, yeah I know it's old. Area of house 21' x 36' x 8' height. How do I calcualte my Btu's.
handyandy is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
How to Size a Furnace super_man4471 HVAC 18 03-25-2010 10:12 AM
Furnace size question IGOTTAHEMI HVAC 6 03-16-2007 06:57 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
