Old 01-09-2012, 10:26 PM   #1
furnace size
what size furnace in btu will i need for 3000sq feet home whit good ins.?
sam mauceri is offline   Reply With Quote
Old 01-09-2012, 10:33 PM   #2
furnace size
Here's a good program for you to do a load calculation with a very reasonable fee.
http://www.hvaccomputer.com/main.asp
Old 01-09-2012, 10:47 PM   #3
furnace size
tnks,but no one do a calculation.they say 80000btu at 95%efficiency should be equaly to my old 100000btu at 80%.
Old 01-09-2012, 11:05 PM   #4
I'm Your Huckleberry
furnace size
The only way to know what size furnace is needed is by way of science ("good insulation" will not cut it), the manual J provided by Marty. It doesn't matter what you had or how it's comparable from 80 or 100 btu's to if it's the wrong size to begin with.
You wanted to know and you were told, plain and simple.
Thanks.
Doc Holliday is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
How to Size a Furnace super_man4471 HVAC 18 03-25-2010 10:12 AM
Furnace size krb HVAC 8 11-14-2009 02:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
