Furnace Shutting Off - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2009, 09:49 PM   #1
furnace shutting off
I have a 1987 Thermo pride hot air furnace. I have always had it serviced, last winter it started shutting off for no apparent reason. The serviceman came and could not find anything wrong. He did clean it and replaced the filter even though he had done this four months before. It continued to shut off every so often, I push the re-start button and it starts . Now after the blower stops there is quite a low bang in the duct work, I don't know if these two things are related. I would appreciate any advice anyone may have. I just lost my husband and can't afford a new furnace.
mary d is offline   Reply With Quote
Old 03-27-2009, 10:27 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I would start by checking the filter
Old 03-27-2009, 10:30 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Sorry to hear about your husband. The low bang is probably the ductwork contracting after it cools down or deflating and making a bang. Nothing to worry about. I assume it is an oil furnace. You should NEVER press the reset button more than once as it may pump unburned oil into the chamber and that is dangerous. There is a reason the burner won't fire and all I can suggest is try a different repairman and maybe he will spot the problem. Perhaps one of your neighbors or friends can recommend someone they have good results with.There are about a dozen different reasons it may fail and some are fairly simple if the serviceman is experienced.
Good Luck
Old 03-27-2009, 11:19 PM   #4
An old Tradesmen
Rewards Points: 6,458
As above, sounds like the duct banging.
Have you checnged or cleaned the air filter lately.
A dirty air filter can cause the temp rise to be high enough to cause the duct work to bang.
The Thermopride, has a life time limited warranty on its heat exchanger.
Your service man just missed what is causing the problem. No need to replace furnace.
Old 03-28-2009, 08:57 AM   #5
thanks everyone, I will follow up on your advice. When the problem is fixed I will let you know what is was.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
electric furnace not shutting off pkuenz HVAC 5 11-17-2008 05:22 PM
Shutting off water to an oil furnace Oldhickory HVAC 4 03-09-2008 01:10 PM
