Furnace Shutting Down After 30 Seconds - HVAC - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 09:46 PM   #1
Furnace shutting down after 30 seconds
I have an older Tempstar gas forced air furnace. It starts up, runs for 30 seconds, shuts down for about 10 seconds then starts up again. Same thing over and over. Have replaced the limit switch, cleaned the flame sensor. Problem still exists. Any ideas?
photvidgal is offline   Reply With Quote
Old 01-18-2012, 10:19 PM   #2
how
Rewards Points: 1,104
Age/ model?
the likely sequence of operation is as follows:
1. Tstat call for heat
2. inducer motor starts and closes pressure switch
3. after a short pre purge igntor will be energized
4. gas valve pilot solinoid is energized and delivers gas to the pilot.
5. pilot flame ignites.
6. sensor confirms the pilot flame.
7. main gas burners comes on and ignite.
8. main blower is energized
8. tstat is satisfied and inducer is de-energized
9. main blower de-energized
How far does it go through this process?
Do you have a diagnostic led light blinking through a door grill or inspection port.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
plummen (01-24-2012)
Old 01-19-2012, 04:05 PM   #3
HVAC Tech/ Browns Fan
Limit goes out for a reason. I bet anything you have a plugged up filter or indoor coil. To even rule out bad t-stat with power off put white and red together and turn back on. If it keeps running then bad stat but most likely plugged up coil.
Tator1076 is offline   Reply With Quote
Old 01-21-2012, 10:22 AM   #4
Thanks for suggestions. Update: what actually happens is it heats up, main fan starts, flames shut off, fan shuts off, flames starts up again.
Old 01-21-2012, 10:25 AM   #5
Filter is brand new. Have even tried it without filter. Heat exchanger is all clean.
Old 01-21-2012, 10:27 AM   #6
Old Temstar. Too old for led indicator.
Old 01-21-2012, 10:33 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 386
post pics of it with both doors off. It is an ICP product and lots of them have cracked heat exchangers or popped rivets which hold the heat ex together. air may be disturbing the flame due to a cracked heat ex. may need to get an experienced Pro to check for that.
The Following User Says Thank You to yuri For This Useful Post:
Old 01-21-2012, 07:26 PM   #8
Can't figure out how to post photos. Will check the heat exchanger. Thank you.
Old 01-21-2012, 07:34 PM   #9
Rewards Points: 582
an easy check is pull blower assy look for rings in bottom of blower...most of the times if exchanger has problems rings will drop there...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 01-22-2012, 09:38 AM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 386
post them on photobucket/image shack/flickr or (go advanced) in this box and then (manage attachments) and upload them. put links here from pbucket or others
Old 01-22-2012, 09:40 AM   #11
Hvac Pro
yuri's Avatar
Rewards Points: 386
that works some of the time but not for cracks, still need to get a Pro with mirrors and a scope.
Old 01-22-2012, 10:47 AM   #12
Checked blower. No problems seen.
Old 01-22-2012, 10:52 AM   #13
Hvac Pro
yuri's Avatar
Rewards Points: 386
I have worked on hundreds of them and know where they crack. They only way to see the cracks is with a mirror/experience of where they crack/inspection scope or to pull out the heat ex from the furnace (gut it like a deer). I am more concerned with your safety as well as solving the problem.
Old 01-23-2012, 03:15 PM   #14
We have 2 furnaces so have switched over to the other one. We so appreciate all the help. We will be revisiting this shortly. Want to get them both functioning soon.
Old 01-24-2012, 12:24 AM   #15
Is it safe to do this?
Or should you just try another thermostat?
Liberator is offline   Reply With Quote
tiling under new furnace gramps416 Flooring 4 01-09-2011 10:47 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Gas furnace briefly shutting down john152 HVAC 4 12-26-2009 05:35 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
LUXAIRE gas furnace shutting off KS_Rehabber HVAC 4 08-23-2004 03:56 PM
