Old 12-07-2008, 09:22 PM   #1
Furnace short cycling
Hi,
I think the furnace in my cabin may be short cycling. It's a 10-15 year old high efficiency Rheem furnance. I noticed that the burner only runs for 60 seconds before cutting out only to refire again in 2-3 minutes and run for another 60 seconds and so on. Here's what I know so far:
  • Fan blower motor runs all the time. (stat doesn't have a Auto/On setting)
  • Vent motor seems to be working - I can stand outside and hear it run and watch it exhaust.
  • It's not cutting out because the temperature has been met - it only caught up to the set point during the day yesterday.
It was -2 F this morning and I was still able to hold 58 degrees in the main part of the house. Luckily I have a wood stove in the addition that keeps that part of the house toasty.
What could some possible problems be?
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 12-07-2008, 11:44 PM   #2
HvacWiz's Avatar
Check the condensate trap, it might be plugged up. Should be located in the blower section.
HvacWiz is offline   Reply With Quote
Old 12-08-2008, 12:46 PM   #3
I'll double check it, but I don't think it's plugged. It's draining condensate pretty well.
Problem with Burnham Oil Furnace short cycling Catherine M Brown HVAC 13 01-29-2009 11:58 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Proportional cycling for gas furnace KE2KB HVAC 7 11-11-2008 08:56 AM
Burnham furnace short cycling ademaggi HVAC 2 02-13-2008 04:51 PM
