Furnace Runs For Short Periods - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2010, 04:26 PM   #1
furnace runs for short periods
Have a carrier model #58msa060 year 2002 runs for 10 seconds shuts of for about 1 minute and runs again never reacing the set temp.
dodge1972 is offline   Reply With Quote
Old 01-08-2010, 05:25 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
Look for a viewing port on the blower door and a flashing LED. Code for that should be on one of the doors or back of main door.
Old 01-08-2010, 09:32 PM   #3
Rewards Points: 163
Maybe going out on high limit?
Got enough air flow, filter clean?
52Caddy is offline   Reply With Quote
Old 01-08-2010, 09:54 PM   #4
probably a plugged secondary, I replace lots of these. Carrier covers these under warranty right now, but many companies won't do the work because the $ isn't that good, and it appears that carrier is catching on that the problem is also with the lack of proper start-up and/or maintenance. Everyone that I do a secondary replacement on has either been over-fired or not maintained properly. You're also in the gray area as to whether your primaries are gone too. I find that around 5 years, only the secondary is gone, at at 10 years both primary and secondary are gone.
hvac benny is offline   Reply With Quote
What runs before furnace starts rosco HVAC 12 03-20-2010 10:57 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Fan runs constently Furnace won't fire BSO HVAC 1 11-16-2008 08:40 PM
furnace cycles, runs for 45-60 seconds shuts down and recycles again ronsmoneypit HVAC 4 02-03-2008 01:46 PM
