Furnace Runs For An Hour Before Radiators Heat Up - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 06:37 PM   #1
furnace runs for an hour before radiators heat up
Why does my furnace run for an hour before the radiators heat up. The system is full, radiators are bled, thermostat is new. Could my circulator pump be too small or do I need a second one? House is a 1 1/2 story with a small addition.
cokeman168 is offline   Reply With Quote
Old 11-18-2011, 06:49 PM   #2
biggles's Avatar
whats the temperature setting on the boiler for the water for the baseboard
Old 11-18-2011, 07:12 PM   #3
Rewards Points: 582
from a cold start some boilers will take 1/2 hr to 45 min to heat up water to 140 +degrees;;;;;copper slantfin or cast iron radiators depends on size of system as well.....may be normal from cold start.....sizes would help
Old 11-18-2011, 07:31 PM   #4
biggles's Avatar
the older boilers actual maintain the water in quantity,but the cold start ones loop the water to pass thru the boiler on passes and out to the house....so if the baseboard itself is cooled off that will take longer to heat up to limit.when you go down to the boiler and don't see the main burner on but the circulator is running check your thermometer on the boiler that is your set point on the controller it has been reached,but the stat is calling for heat still as the circulator running will indicate
Old 11-23-2011, 07:21 PM   #5
Thanks Fellas! I guess it's just due to starting from cold. It ony runs 2-3 times a day...even when we're in the dead of winter...so I should probably not complain. Thanks again for your help.
Old 11-23-2011, 08:41 PM   #6
biggles's Avatar
think about the stat satisfying and the house is comfortable for that stat to call again for heat the temp has to go below your setting say 68F-70F imagine the temperature of the water in the baseboard/radiators and a cold wall before the stat feels it...your good to go... if you have old fashion radiators with a bear wall behind them building radiator covers with insulated backs will get the heat reflected quicker out into the rooms...slipping a sheet of foil backed styrafoam might not go good with the room decor. heat always gravitates to the coldest area reflecting it out covered or not..something to consider
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Service tech won't repair furnace with cracked heat exchanger. GloBigRed HVAC 16 11-18-2010 02:27 AM
Installing natural gas furnace in place of heat pump, please help KlamathMog HVAC 17 10-20-2009 01:55 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
