Furnace Running In Fan Mode? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 03:31 PM   #1
Rewards Points: 189
Furnace running in fan mode?
Hi and thanks for the help.
We have 2 furnaces in our house but no AC ..
Temps are in the high 70's / low 80's and I am looking for some extra circulation ..
Is it OK to run the furnace in "Fan Mode" for extended periods of time?
The reason I ask is on our thermostat the fan settings are either On or Off which means we will eventaully leave it on when we leave the house or go to work, etc.
Is there any harm in having the fan on for hours/days at a time?
(both furncaces for what its worth are HE 95% Goodman and a york, less than 1.5 yrs old.)
Thanks again.
beachfront71 is offline   Reply With Quote
Old 09-23-2012, 05:40 PM   #2
biggles's Avatar
with no ac your going to just ciculate the swinging sun as it travels over the house,might be better leaving the upstairs windows open with screens...to cross vent
Old 09-23-2012, 05:51 PM   #3
how
Rewards Points: 1,104
No harm from running the fan 24-7 except the marginal fan motor wear factor and you needing to pay more attention to the fan filters.
how is offline   Reply With Quote
Old 09-23-2012, 07:35 PM   #4
Rewards Points: 582
agree with how no harm in running fans...keeps air moving..even if it is hot air
Old 09-23-2012, 07:43 PM   #5
An old Tradesmen
Rewards Points: 7,808
Should not be a fan off setting on your thermostat. As the thermostat can't shut off the fan during a heat call.
The fan motors in furnaces are designed to be able to run 24/7/365 with no harm to them.
The Following User Says Thank You to beenthere For This Useful Post:
Missouri Bound (09-23-2012)
Sears GAs furnace issue with burner running too long dmanmtl HVAC 17 01-03-2012 09:41 PM
Long running furnace hurt heat exchanger? quincy HVAC 6 11-09-2010 06:01 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
gas furnace keeps running thermostat off cblake HVAC 1 03-31-2009 12:55 PM
fan does not work in "auto" mode on my Lennox Pulse 21 gas furnace OliverMogan HVAC 1 01-22-2009 08:54 AM
