#16 |
furnace run time ?
Fix'n it:
I'm with you on this thread, I just had a high efficiency unit installed (95%) and it seems as if runs more than my old unit (78%). My home was built in the early 90s. I've been watching the gas meter every few days and comparing my bills with last year, and I am using about the same amount of gas. Any one here able to tell me if this is to be expected? |
#17 |
Items wanted: Time
furnace run time ?
Nobody can give you anything even resembling an accurate answer to that question Way too many variables
#18 |
furnace run time ?
I'm sorry. 95% efficiency 105k btu in 1900 sq foot home. Runs around 4-5 times an hour for anywhere from 5-10 minutes.
#19 |
Items wanted: Time
furnace run time ? |
#20 |
#21 |
Items wanted: Time
furnace run time ?
Type of home. Outdoor temperature. Time of day. Sun shining. People in the home. Ductwork. Filter. Setpoint.
#22 |
HVAC Tech/Owner
furnace run time ?
How big was your old furnace?
105k for a 20 year old 1900sqft house sounds excessive....where are you located? My 2000sqft house built in the same time period only needs 35k down to 18F. |
#23 |
furnace run time ?
yeah. so surrounding items that have heat in them, don't effect what the thermometer is reading = it is reading only the air temp.
furnace = 70degrees it turns on. 74 degrees it shuts off.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
| Display Modes | |
| Bryant 394J Furnace - Pilot stays ON all the time | Davexxx | HVAC | 17 | 04-08-2012 07:46 PM |
| Moving furnace & redoing ducting | cbrc5eric | HVAC | 0 | 02-09-2012 09:13 AM |
| Furnace fan won't switch on--unpredictable intermittent problem | arvonon | HVAC | 3 | 01-22-2012 05:46 PM |
| first time startup on Bryant furnace - furnace calls for heat and will not stop | luvheat | HVAC | 22 | 02-14-2009 09:56 AM |
| Problem with Trane gas furnace | quovadis | HVAC | 17 | 12-22-2008 02:12 PM |
