Furnace Room Vent With Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 10:42 PM   #1
Rewards Points: 95
Furnace room Vent with fan
I have a vent in my furnace room about 3".
During the summer it's really hot in there. I was thinking of putting o fan inside the vent. I thought about wiring it so that it goes on at the same time the furnace fan goes on but I only need it during the summer. I also thought about getting a 110v fan and plugging it into a timer that I can set to turn on a few times a day. I also thought of putting a thermostat of some kind in the room and wiring it to the fan, but I am not sure what kind of thermostat to get.
Does anyone have any suggestions on what else I could do?
grod777 is offline   Reply With Quote
Old 10-31-2011, 01:16 AM   #2
how
Rewards Points: 1,070
A bunch of questions come up with this one.
What type of gas equipment is in your furnace room? Gas hot water tank, standard/mid or high efficiency furnace? How is that equipment now being vented. Is it powered or atmospheric? Is that small 3" vent going to the outside? How is the fresh air now getting to the gas appliances? Is the furnace room sealed or do you have vents to allow air from the house into the furnace room.
There are simple bi-metal fan controls that will temp operate an exhaust fan but I think anyone here would ask for a lot more info to know that its instalation wouldn't also hurt you or the gas equipment with your furnace room set up.
how is offline   Reply With Quote
Old 10-31-2011, 10:14 AM   #3
Rewards Points: 95
It is a electric powered, gas, forced air furnace with a coil installed 2 years ago,not sure on efficiency but I would guess it's very efficient being that it's 2 years old. I also have a new gas hot water heater that was just installed in the same room.
The flue pipes for both are vented outside.
There are 2 fresh air vents in the room that vent outside. The room is closed off with a door.
Let me know if that enough info.
Fresh Air Intake for Furnace Room. Help Needed samantha.77 HVAC 28 10-09-2012 10:53 AM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
How does my gas furnace get air to combust the gas? What if the room is sealed? Vincer HVAC 8 03-24-2011 01:00 PM
Direct Vent Wall Furnace - Pilot-Help !! roztom HVAC 4 04-28-2010 11:25 AM
question about a direct vent gas wall furnace utilitylocator HVAC 1 03-16-2010 09:52 AM
