Furnace Room Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 12:41 PM   #1
dtw
furnace room vent
can you tell me if such a vent that you can buy that when your furnace come's on it will open to let air in then when furnace go's off it will close like a shutter ?
dtw is offline   Reply With Quote
Old 10-29-2011, 12:53 PM   #2
Rewards Points: 6,652
You only need a fresh air intake, if your home is so air tight, that there is no way for air leakage, or that the boiler/furnace and/or water heater is in a finished space.
Old 10-29-2011, 01:19 PM   #3
biggles's Avatar
but the room will end up chilling out in the dead of the winter.they only item they have had for years is a Honeywell flue damper that opens on stat heating call stays open during the cycle and coses when sta is satisfied....for GAS applications only bioler or furnaces...oil is not allowed...whats wrong with the air as it is in the basement.keep in mind the furnace and boiler heat the house air at say 70F if your bringing in OA at 30F your bills are going to climb to make setpoints
Old 10-29-2011, 04:55 PM   #4
Rewards Points: 79
You could put a louvered vent on the inside and a fan in the pipe. Wire the fan to come on with the blower
Dwillems is offline   Reply With Quote
Old 10-30-2011, 01:25 AM   #5
Rewards Points: 79
I just saw something that would work. Look up motorized air dampers. Wire that to open up when your furnace kicks
vent bathroom fan to furnace vent jcrampton HVAC 16 10-11-2012 11:24 PM
Fresh Air Intake for Furnace Room. Help Needed samantha.77 HVAC 28 10-09-2012 09:53 AM
How does my gas furnace get air to combust the gas? What if the room is sealed? Vincer HVAC 8 03-24-2011 12:00 PM
Direct Vent Wall Furnace - Pilot-Help !! roztom HVAC 4 04-28-2010 10:25 AM
question about a direct vent gas wall furnace utilitylocator HVAC 1 03-16-2010 08:52 AM
