Old 09-30-2012, 03:23 PM   #1
Question
furnace replacement and evaporator coil leak
Can replacing a furnace cause a leak in the evaporator coil? Must the technician handle the evap. coil during replacement of the furnace?
Armylis is offline   Reply With Quote
Old 09-30-2012, 04:38 PM   #2
Yes, they both in there together.
clocert is offline   Reply With Quote
The Following User Says Thank You to clocert For This Useful Post:
Armylis (10-02-2012)
Old 10-02-2012, 08:14 PM   #3
Depends if they had to move the coil to perform the install.. if its just a simple furnace replacement its unlikely they damage the coil. IF its a leak that can no longer hold freon.. its likely they accidently punctured the coil, if the coil is aged and has a small leak, was most likely there prior to replacement
Nickhvactech is offline   Reply With Quote
Old 10-02-2012, 09:11 PM   #4
An old Tradesmen
On a standard split system furnace with A/C. The indoor coil is disturbed during the change no matter how careful you are. So a leak at the press sheet can happen. Its an incidental thing. Many companies will inform their customers of the potential before they change out the furnace, and offer to install a new coil at the same time at a lower price then if they have to come back later and change it out.
Old 10-02-2012, 10:04 PM   #5
yep it does happen... doing install in the morning informed home owner coil is 23 yrs old it may get damaged ....she is a tough one ...if its not broke you won't fix it can't sale her a new a/c system ...been servicing her a/c for 15 yrs it won't die...ben sr..... by the way its running better than some new ones..
