Furnace Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 09:37 AM   #1
Rewards Points: 16
Furnace Replacement
OK as a novice, I believe years ago much like water heaters, you were told that there were only "x" number of furnace makers for all.
I believe that in this day and age, this has probably changed or was just a line. So in preparation for a sales pitch, what furnace makes should we stay away from? Which to go with?
We dont need one with a lot of bells and whistles. Here are what we know we need:
4 ton ac 1600 CFM support
High 90's efficient
Heating: Replace 80% 60k/48k out
Got one bid for a Goodman GMH950704CX, thoughts on Goodman if you can?
Dont really want one that has a "constant fan" or always on low fan.
Thanks for thoughts.
digitalplumber is offline   Reply With Quote
Old 08-07-2012, 10:07 AM   #2
First and foremost: The most important part of this equation is the quality of the installation, which is directly related to the quality of the contractor. Do your homework, ask around to friends/neighbors/co-workers for recommendations of contractors, etc etc. Don't shop based solely on price - the cheapest install is rarely the best. Find out as much as you can about the contractors, find someone you feel you can trust, and deal with them.
I am not big fan of Goodman but I've rarely had troubles with their standalone furnaces. IMO Trane/American Standard are the best products on the market today, but of course that's just my own personal opinion and is not shared by everyone.
No furnace defaults to a constant on fan system. That's controlled by the stat, or in some cases by conditions present in the furnace - e.g. a faulty limit can sometimes cause the fan to run all the time, to alert the homeowner of the condition.
scottmcd9999 is offline   Reply With Quote
Old 08-07-2012, 04:52 PM   #3
Rewards Points: 16
Thanks I understand what you are saying, but finding a very good tech is hard to do.
Not sure I agree with having a very good tech install inferior equipment correctly?
Thought I read some specs on a Goodman that had an always on low fan, in heat mode I believe? Could be wrong.
Thanks for your answer.
Old 08-07-2012, 05:14 PM   #4
An old Tradesmen
Rewards Points: 6,112
Well, if your current 48,000 BTU output furnace is heating your house ok, then you might want to consider a 2 stage furnace. Since a 70,000 BTU 95% efficient furnace will be 66,500 BTUs output. And tend to short cycle, and not really save you any money on the heating bill.
As said earlier, the fan is not constantly on on a furnace, unless the stat is set for it.
Old 08-07-2012, 05:17 PM   #5
Rewards Points: 16
"Low constant fan mode allows the homeowner to activate the lowest available heating speed to circulate air quietly and efficiently throughout the home during the off cycle"
Old 08-07-2012, 05:23 PM   #6
An old Tradesmen
Key phrase. Allows the home owner to "activate". If you don't "activate" it, then the blower won' run constantly.
Old 08-07-2012, 05:24 PM   #7
Rewards Points: 16
Yep, apparently its within the unit itself and not at the thermostat.
Old 08-07-2012, 05:28 PM   #8
Rewards Points: 16
[quote=beenthere;983648]Well, if your current 48,000 BTU output furnace is heating your house ok, then you might want to consider a 2 stage furnace. Since a 70,000 BTU 95% efficient furnace will be 66,500 BTUs output. And tend to short cycle, and not really save you any money on the heating bill.
Yep, any suggestions? is 70K going to be the lowest with 1600?
Old 08-07-2012, 05:32 PM   #9
An old Tradesmen
ya, not going to find anything smaller with a 4 ton blower. Goodman has a 2 stage 70,000 BTU furnace. But stay away from their GMH 2 stage furnace. It times to second stage.
Old 08-07-2012, 05:36 PM   #10
Rewards Points: 16
Thanks, yes I had read that, that the goodmans were not a "true" 2 stage.
Thanks for all of your input!
Old 08-07-2012, 05:39 PM   #11
An old Tradesmen
Its still a "true" 2 stage. Its comfort ability is just crippled. Its Goodman's answer to price on 2 stage furnaces.
Goodman's GMV/GMVC is a good choice, and has a VS blower.
Old 08-07-2012, 05:44 PM   #12
Rewards Points: 16
Thanks for all of your advice on this.
Old 08-07-2012, 06:41 PM   #13
One more piece of advice...if you get the goodman purchase the extended labor warranty. It's cheap and will pay for itself the first time it breaks down.
Old 08-07-2012, 07:22 PM   #14
Rewards Points: 582
we have armstrong units that can be set to fan on low continous duty...its done on the control board....as mentioned not by stat...
Is my 27 year old furnace & A/C in need of replacement? Mr Blotto HVAC 20 11-13-2012 06:54 PM
Some questions regarding furnace replacement Allears HVAC 3 05-27-2012 03:26 AM
replacement part for Aire-flo furnace? BlueBSH HVAC 9 09-14-2010 09:41 AM
Furnace combustion chamber replacement tripower HVAC 2 10-21-2008 07:39 PM
Furnace Replacement Options? Genhawk21 HVAC 5 01-11-2008 10:41 PM
