Furnace Questions - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-09-2009, 05:18 AM   #16
Thanx for the link CustomBuild, I'll check it out later. In my previous post it states: "I am told" regarding the insulation in the attic. My landlord informed me that the insulation is in fact shredded newspaper, no mistake. Shouldn't this stuff be replaced after 35 years??? Also, thanx for the throw rug tip, it's been suggested to me a few times. I'd need some really thick underlay & wall to wall berber to keep the cold out here, where it gets close to minus 50!!! And my pocketbook ain't that large!
Lali is offline   Reply With Quote
Old 11-10-2009, 11:32 AM   #17
greengiant's Avatar
Newspaper? Well you could hope your landlord is wrong. Maybe it has even been treated with fire retardant. Newspaper is great bedding for rodents and for starting fires.
A relatively inexpensive upgrade would be to install some weather stripping and door sweeps. That should help reduce infiltration and heat loss. A larger concern is: what is driving the infiltration (what is sucking the outside air inside)? Is there a fireplace that draws air from inside? Airflow from the house into the attic? A faulty furnace installation?
greengiant is offline   Reply With Quote
Old 11-10-2009, 03:37 PM   #18
An old Tradesmen
Rewards Points: 8,144
Common in cellulose insulation.
Old 11-11-2009, 04:25 AM   #19
Thanx for the tip about the rodents & starting fires 'greengiant'!And 'beenthere' it was treated with fire retardant(well, probably 35 years ago). No fireplace, new front & back doors installed; one this year & one two years ago. Highly likely faulty furnace installation (no initials on inspection sticker!!!) or could possibly be airflow into attic. Next ???
Old 11-11-2009, 06:36 AM   #20
Back again. Just read ALOT on link from CustomBuild (Thanx a mil, I learned aload). Plan to call utility company for an energy audit in the near future. Am certain this place could use a complete overhaul!!! Will let you know the gig when it's up! Aloha!
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
newmac wood/oil combo forced air furnace questions CowboyAndy HVAC 2 09-22-2008 05:17 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
