Furnace Question Cuts Off Until I Hit The Reset Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 02:47 PM   #1
Furnace question cuts off until I hit the reset switch
Why would my furnace cut off and then need to be reset to turn it back on? It just stops working until I go and turn the reset switch off and then back on, what would be the reason for this? Any help would be greatly appreciated .
bmvrdv is offline   Reply With Quote
Old 12-08-2008, 04:21 PM   #2
An old Tradesmen
Rewards Points: 7,270
Hmmm.
Winder if its an oil or gas furnace.
Newer or older furnae.
If its gas, natural or propane.
Old 12-08-2008, 04:59 PM   #3
By meaning reset switch do you mean the breaker?
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 12-09-2008, 07:56 AM   #4
Gas
It's a Gas furnace and it's about 10 years old. By swtich I mean I have a "light" switch attached the furnace, so I have to turn it off and then back on and it works fine after that, for awhile. Sometimes a fews hours and sometimes a day before I need to turn it off and on again.
Old 12-09-2008, 08:28 AM   #5
The list is long of what it could be. The switch could be bad or anything else past it like the flame sensor, pressure switch....I could go on an on.
Do you have a multimeter, know how to use it and comfortable testing live 120v circuits?
Also tell us what brand and model furnace it is.
Old 12-09-2008, 09:29 AM   #6
Yea..Sounds like maybe your switch/wiring is faulty if the furnace is working fine otherwise..
Id put a new one in before doing anything else. Only lose $2 and about 5 minutes if it doesn't solve it.
Tommy2 is offline   Reply With Quote
Old 12-09-2008, 09:40 AM   #7
Oh Tommy! $2.00 for a light switch? I get them for 75Cents. Charge 30 plus service to replace. Lowes on sale.
Buy 'em ten at a time it's cheaper 'bro.
hvaclover is offline   Reply With Quote
Old 12-09-2008, 09:54 AM   #8
Before you replace it, test it to see if that is the problem. Once it shuts off then test the load side and see if you have any juice. No juice? Replace the switch and problem solved.
It's always good to know what the problem was. Consider it learning.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Electronic ignition furnace question rcossebo HVAC 4 11-23-2008 01:02 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
HEIL furnace keeps kicking off reset switch sunsetacres1318 HVAC 8 11-04-2008 08:35 AM
Furnace Emergency Switch Placment arichard21 Electrical 2 01-21-2008 11:32 AM
