Furnace Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 01:49 PM   #1
Furnace Question
Hi! I recently needed to have my recirculator pump replaced and I now have air in my system. At the same time of the replacement, I also had a new float air vent installed. My questions are:
1. Should the cap on the float air vent always remain loose? When I went to check the system the cap was tight and when I turned it a lot of air came out.
2. Do I need to add more water to the system to replace the air? It seems like the "river" sound in the pipes is louder since I released the air.
Make/Model - Hydrotherm HC-125C
Thanks!
Jontrax4 is offline   Reply With Quote
Old 01-02-2011, 02:23 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... #1, Yes, they should be abit loose....
#2, you should have an auto-refill valve, is it hooked up,..?? is the valve in it's line open,..??
Old 01-02-2011, 02:29 PM   #3
The supply line is off, if I turn it on will it supply it automatically? Also, should I let the system cool down before opening the supply line?
Old 01-02-2011, 02:33 PM   #4
Experienced
Jackofall1's Avatar
To ask if it will feed automatically....hmm....without a pic, without knowing whether you have a autofill valve, we won't know whether you have a autofill valve.
No you don't have to cool down the system, and if you do have an autofill valve I would suggest you leave the fill line open all the time or at least until all the air is chased out of the system.
Old 01-02-2011, 02:39 PM   #5
The fill valve looks like this: http://www.google.com/imgres?imgurl=...w=1003&bih=563
Old 01-02-2011, 03:03 PM   #6
Bondo's Avatar
Originally Posted by Jontrax4 View Post
Ayuh,... That's an Auto-fill,... It should be pre-set to 12psi....
Old 01-02-2011, 03:20 PM   #7
Ok great, thanks for the info! So basically, I turn the water supply line on (and keep it on) an let it fill whats needed which will eventually work all the air out of the float vent?
In addition, my pressure gauge is broken. Is it easy to install a new one?
Old 01-02-2011, 03:34 PM   #8
Bondo's Avatar
Ayuh,... If you have manual bleeds in the system, it don't hurt to atleast Try 'em, to get the bulk of the air out of the system....
There'll be a loss of water, Hot water, so ya gotta be Ready, 'n work Fast....
But it ain't that biga deal, No...
Furnace supply temperature question rlukas79 HVAC 4 12-19-2010 05:52 PM
Furnace port, and combustion chamber crack question. cjf1980 HVAC 0 07-27-2009 09:23 PM
Gas Furnace Question CoreyK HVAC 8 04-07-2009 05:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
