Furnace Question - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 10:13 AM   #1
furnace question
Can anyone tell me information on lennox G26Q 3/4 -125-1
as to how old this furnace might be heating capacity and especially efficiency rating
trump is offline   Reply With Quote
Old 10-12-2009, 10:17 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
92% efficient, 125,000 BTUs. I am a Lennox tech. Give me the serial # and I can tell U the age.
Old 10-12-2009, 10:27 AM   #3
serial number 5894M31896
Old 10-12-2009, 10:34 AM   #4
would you recommend this furnace for installation in a 1000 sq foot home per floor 2 floors (basement and main)
Old 10-12-2009, 10:39 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
1994. Where do you live. That furnace should easily handle a 2000 sq.ft home. Depends on where you live as well and how well insulated the home is.
Old 10-12-2009, 10:46 AM   #6
live in b.c. older home 2x4 walls so not the best for insulation
thanks for all your info
Old 10-12-2009, 10:50 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 396
Should be ok. Good for Wpg that size. It needs regular maintenance, flame sensor cleaned etc.
Old 10-12-2009, 12:11 PM   #8
The ductwork needs to be adequately sized for that furnace or you will have problems. Lockouts due to high limit etc..
SKIP4661 is offline   Reply With Quote
Old 10-15-2009, 06:44 PM   #9
wiring question
when this furnace was taken out the wires were cut and i am not sure whats what there, I have a larger black and white wire i assume is for 110 however there is no green there for ground. There is also a smaller wire with 5 strands coming from the terminals and another one with 2 strands .
any idea whats up with that
thanks
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Furnace question cuts off until I hit the reset switch bmvrdv HVAC 7 12-09-2008 09:54 AM
Question Re: New Furnace and Duct Sizing DSimo HVAC 3 06-17-2008 07:24 AM
