Furnace Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 09:16 AM   #1
furnace question
My miller furnace has to be primed to start every time it will run once i do that but when it shuts off it wont restart itself it has to be primed again what could be the problem??
hummingbird665 is offline   Reply With Quote
Old 11-11-2011, 03:06 PM   #2
REP
You either have a loose connection in your fuel line or your fuel pump is bad.I've seen plenty of both but probably more bad pumps.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
hummingbird665 (11-12-2011)
Old 11-11-2011, 03:21 PM   #3
An old Tradesmen
Rewards Points: 8,174
Could be a loose connection in the oil line, or a bad pump valve or a bad pump seal.
The Following User Says Thank You to beenthere For This Useful Post:
Central air evaporator and furnace placement question. StretchinAZ HVAC 4 05-09-2011 07:43 PM
Furnace supply temperature question rlukas79 HVAC 4 12-19-2010 05:52 PM
Furnace port, and combustion chamber crack question. cjf1980 HVAC 0 07-27-2009 09:23 PM
Gas Furnace Question CoreyK HVAC 8 04-07-2009 05:11 PM
