Furnace Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 08:04 PM   #1
furnace problems
i have olsen furnace with a beckett burner..the furnace will not come on by itself..once it is cut in manually after it stays running for about 2 hours it will cut out and not come back on again until once again done manually....help...had an oil burner mechanic look at it and he said beckett is garbage
poff is offline   Reply With Quote
Old 01-05-2011, 08:35 PM   #2
An old Tradesmen
Rewards Points: 6,470
Probably needs a good cleaning and tune up.
Old 01-05-2011, 08:50 PM   #3
JJboy's Avatar
Can you describe these two procedures cleaning and tune up?
JJboy is offline   Reply With Quote
Old 01-05-2011, 08:59 PM   #4
Experienced
Jackofall1's Avatar
JJ as opposed to someone trying to describe this process you might want to search the net, tuneup NG furnace, clean NG furnace etc there is plenty of info out there on how to.
Old 01-06-2011, 04:57 AM   #5
An old Tradesmen
Flue pipe removed, brushed and vacuumed clean. Furnace clean out ports opened, brushed and vacuumed.
Nozzle draw assembly removed, cleaned, and nozzle replaced, oil pimp strainer changed/cleaned on Suntec pumps. Along with new oil filter.
Unit reassembled, flue pipe reinstalled. Furnace ran and combustion set up by combustion test equipment.
The Following User Says Thank You to beenthere For This Useful Post:
JJboy (01-06-2011)
coleman furnace blower motor problems coleman7970-856 HVAC 3 11-27-2010 07:51 PM
Concord 90 Plus Gas Furnace Problems turby HVAC 4 11-08-2010 08:38 PM
Furnace and air vent problems dsd HVAC 3 06-15-2010 08:28 AM
Furnace problems Charlie Brown Electrical 2 10-01-2009 07:34 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
