Furnace Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 06:29 AM   #1
furnace problems
we have a 1994 american standard freedom 90 furnace . the main blower comes on at start up. the exhaust blower comes on like it should but i do not think the main should come on till it comes up to temp.we installed a new programmable thermostat about a year ago i am not sure if it started then or not ,i should of paid more attention.could i have wired the thermostat wrong or do i have a sensor bad? i hope some one does not tell me it needs a circuit board,that looks expensive thanks.
gwamer is offline   Reply With Quote
Old 02-08-2010, 07:11 AM   #2
furnace problems
Try and find your thermostat manual. When they are set up for electric heat the blower comes on right away. Need to change it to gas.
Old 02-08-2010, 02:07 PM   #3
furnace problems
that was it . i went online and found the manual and there was a jumper on the back ,made the change and it works like it is suppose to.thanks alot you really helped me out.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace problems Charlie Brown Electrical 2 10-01-2009 07:34 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
